Question about aircrafts
I have been checking out your software and just have a quick question before I dive into to it.  Is the software written such that it links a given profile to a given aircraft in the same way that LINDA does.  Ex.  If I load the comanche 250 up it will load a profile for that plane and if I switch to the P-40 it will load one for that vehicle. Or does it need to be manually loaded each time?
Kind regards,
Brett
  • Hi Brett,
    Yes it is aircraft aware and loads the correct config when the loaded aircraft changes. You can even use a shortened aircraft name so one config can handle an aircraft with multiple liveries.
  • Thanks Steve!   Looks like I have some programming to do :)
