Problem with GF-MCP
I get a yellow status light within the PMDG interface. I have the GF-MCP (not Pro). My log looks like this:
13:31:57 GoFlight Connection Starting.....
13:31:57 SimConnect Connection Starting.....
13:31:57 GoFlight Connection Started
13:32:17 SimConnect Message Processing Started
13:32:17 SimConnect Connection Started
13:32:17 Aircraft Connection Starting.....
13:32:17 Aircraft Connection Started
13:32:18 Synchronising Switches & Selectors .....
13:32:18 Synchronising Switches & Selectors: Waiting for Simconnect .....
13:32:21 SimConnect: Event Received: Start
13:32:21 PMDG SDK option is OK in FSX
13:32:21 Prepar3D registry AppPath entry not found
13:32:35 SimConnect: Event Received: Aircraft Type Changed
13:32:35 SimConnect: Event Received: SIM, 0
13:32:35 SimConnect: Event Received: PAUSE, 0
13:32:35 SimConnect: Exception Received:  OUT_OF_BOUNDS
13:32:35 SimConnect: Event Received: Quit
13:32:35 GoFlight Connection Starting.....
13:32:35 GoFlight Connection Started
13:32:35 SimConnect Connection Starting.....
13:32:35 SimConnect Message Processing Started
13:32:35 SimConnect Connection Started
13:32:35 Aircraft Connection Starting.....
13:32:36 Aircraft Connection Started
13:32:36 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
13:32:36 SimConnect: Event Received: SIM, 0
13:32:36 SimConnect: Event Received: PAUSE, 1
13:33:16 SimConnect: Event Received: SIMSTART, 0
13:33:16 SimConnect: Event Received: SIM, 1
13:33:18 SimConnect: Exception Received:  ERROR
13:33:19 SimConnect: Exception Received:  ERROR
13:33:21 SimConnect: Exception Received:  ERROR
13:33:22 Synchronising Switches & Selectors Complete
13:34:19 GoFlight Connection Starting.....
13:34:19 GoFlight Connection Started
13:34:19 SimConnect Connection Starting.....
13:34:19 SimConnect Message Processing Started
13:34:20 SimConnect Connection Started
13:34:20 Aircraft Connection Starting.....
13:34:20 Aircraft Connection Started
13:34:20 Synchronising Switches & Selectors .....
13:34:20 Synchronising Switches & Selectors: Waiting for Simconnect .....
13:34:20 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
13:34:20 SimConnect: Event Received: SIM, 1
13:34:20 SimConnect: Event Received: PAUSE, 0
13:34:21 SimConnect: Exception Received:  ERROR
13:34:22 SimConnect: Exception Received:  ERROR
13:34:23 Synchronising Switches & Selectors Complete
13:39:07 GoFlight Connection Starting.....
13:39:07 GoFlight Connection Started
13:39:07 SimConnect Connection Starting.....
13:39:07 SimConnect Message Processing Started
13:39:07 SimConnect Connection Started
13:39:07 Aircraft Connection Starting.....
13:39:07 Aircraft Connection Started
13:39:07 Synchronising Switches & Selectors .....
13:39:07 Synchronising Switches & Selectors: Waiting for Simconnect .....
13:39:08 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
13:39:08 SimConnect: Event Received: SIM, 1
13:39:08 SimConnect: Event Received: PAUSE, 0
13:39:08 SimConnect: Exception Received:  ERROR
13:39:09 SimConnect: Exception Received:  ERROR
Can you help?
Also, the last digit to the far right of the alt indicator on the GF-MCP panel doesn't light up. It does for the default FSX 737. Because of this I can't dial above 10,000`. Any suggestions?
Thank you!!
Mike Gruesen
  • edited November -1
    Hi Mike,
    It's probably one of two things:
    - You haven't correctly added the GIT dll into dll.xml (details in the beta quide manual)
    - You are using an old version of the Goflight Drivers.
    Thank you Steve!
    Where is the beta guide manual found and what is the latest driver version for GoFlight?
    Thanks again!
    Mike
    Hi Mike,
    All Programs under PollyPot Software (Goflight Interface Tool User Guide).
    Latest drivers are here: http://www.goflightinc.com/pages/support
    Was wondering, I am only using PMDG's 737 with a GF-MCP (not Pro)... Should I be using the GoFlight PMDG Interface or the GoFlight Interface Tool both found on your website...
     Also, would the latest GoFlight Drivers load if I loaded GF Config Setup 2.23 from GoFlight?
    Mike Gruesen
    Hi Mike,
    The Goflight PMDG Interface is no longer being developed. GIT replaces it and does much more. GIT will be the product that will support the PMDG 777, so I would suggest moving to it at some point, but there is no rush since you only use the MCP (if you had GF166's I would recommend an immediate move).
    I haven't tried 2.23, but I can't see why you would have a problem. Give it ago and if it doesn't work you can quickly uninstall and reinstall your prior drivers.
