Setting Up the Q400
Slowly but surely am figuring things out in my attempts to set up the Q400. When I tackle a new switch I would like to know the best step by step approach to figuring it out.(Hopefully there is one)
By way of example, the ANIT-SKID switch. Here's what I did.
1) Searched the mouse clicks list that have been uncovered with no luck.
2) Spent some time testing some other mse clks with no luck. Still a lot left to check and some that appear to do nothing, but it is hard to tell.
3) Looked in the lvar.xsl for anything that looked like it might apply, no luck.
4) Ran Detective and found this when I clicked the switch on:
GS_ANTISKID_SW Lvar Data: 1
Lvar : MJC_VAR_READ_CODE Lvar Data: 9991999
5) Created a bespoke event with 0 and 1 being on and off. The switch goes up and down between on and off.
6) Noticed while the switch moves nothing happens within the sim. When I click the switch in the sim the warning lights come on, on the panel and a tone sounds. When I use my bespoke the switch moves but no action.
7) So, I tried to incorporate the READ_CODE .... 9991999 using the 4 MJC_VAR_read/write/code/value. No luck.
8) Under events I found 66720 ANTISKID_BRAKES_TOGGLE. Not sure how to use this.
Am on on the right track as far as the step by step process goes? Where do I go from here?
Dave
Dave
Dave
Hi Dave,
Follow this guide to get the codes: http://www.pollypotsoftware.org.uk/support/forum.html#/discussion/230/how-to-guide-build-bespoke-events-for-the-majestic-dash-q400
Have you ever had a look at the APU buttons?
I am trying to figure them out. I have 4 push buttons on a P8 set up to turn on the APU power, starter, gen, and bleed air. Have them set up with the variables 1 for on and 0 for off with the appropriate codes, (without comma's :-)).
Works to turn everything on, but I can't get the same button to then turn off the APU power, generator, or bleed air.
Any tips on how to do this?
Dave
I tried the APU push buttons with mouse clicks but I had the same issue. The first push of the button would turn each of them on, but when I pushed the button again nothing would shut off. I will also try the mouse clicks again. Perhaps I set something incorrectly. So the input to use is leftmouseclick2x?
Interesting that my mouse clicks are different???
163 APU Power
164 APU Start
165 APU Get
166 APU BAir
Thanks again!
Dave
Ill take a look at those switches when i get home and see what they need
I had also tried the separate bespoke for on and off and I couldn't get it to work either. Once again it would turn a button on, but when I pushed it again it would not shut it off. Tried different button actions and I couldn't get the correct combination. This was puzzling because It did work on the detective page when I pushed the test button for both on and off events. When I tried to set them up on the P8 I couldn't get the button to respond to off after it turned on.
So I experimented with how you said you did a toggle. I had the same result. Would turn the button on, but not off in the detective test. Is this anywhere close to what is required?
:on
If MJC_VAR_WRITE_VALUE = 1 Next Else NextSkip
MJC_VAR_WRITE_VALUE = 0
MJC_VAR_WRITE_CODE = 53623
:off
If MJC_VAR_WRITE_VALUE = 0 Next Else NextSkip
Contining to tinker with it....
Dave
Hi Dave,
You need to be careful with P8's because they are push buttons. When you press the button the "ON" event triggers and when you release the button the "OFF" event triggers. So both the "ON" and "OFF" Events will run after a single button press.
I was wondering if the functionality of the buttons had anything to do with it, however when I try using the P8 or RP48 for things like the RECIRC fan and BLEEDS, one push turns them on and another push turns them off. That having been said I still can't get them to work for the APU buttons.... sigh!
Haven't given up yet!
Dave
Because first you tell it what to write, the the code to send it to.
In your case you need to first read 53623, compare it with zero and1 like you are doing.
The only change you need is to your first lines of on and off. I think its mjc_var_read_value 53623. But im not in front of a pc at the moment. Its in the sticky post on the mjc
Also as the code reads, the :on tasks flow straight into the :off tasks. Make sure you have a Goto :end or something after the :on block of tasks, otherwise you will be turning it on, then off.
:on
MJC_VAR_READ_VALUE = 53623
If MJC_VAR_WRITE_VALUE= 1 Next Else NextSkip
Goto end
:off
If MJC_VAR_WRITE_VALUE= 0 Next Else NextSkip
:end
Doesn't move the button in the sim on or off using the test button in GFIT.
Thanks for your continuing help.
Dave
Before I saw your last post I had spent the time creating what I did and posted it. When I tried your suggestion it does turn on the APU power (GFIT test button) but will not then turn it off.
When I took your suggestion and altered my last attempt ( changing "If MJC_VAR_WRITE_VALUE= X Next Else NextSkip" to "if MJC_VAR_READ_VALUE = X Next Else NextSkip") it turns on the power but does not turn it off.
I can only think that I am doing something wrong with the way I set up the toggle and/or the way I set up Steve's suggestion with the Goto :end
Thanks for the quick response.
Dave
Well you did it! The event works on my P8. Love it! Will spur me on to work on the other 3. I am just a few buttons away from doing a mouse-free preflight and start-up!
It still took a little tinkering to make it work and I am sure it was just a typo on your part. I will point it out just in case others are following along and will want to set this up.
I believe I have read through all the documentation in the manual and would never have been able to figure this out. Is there somewhere I can go to learn more about this programing? Hate to be always bugging you for help!
Thanks a million!
Dave
My programming experience comes from school in the 1970's when we had to take the punch cards to the computer room to have the program run by the teacher to see if you got it right!! :-) A love/hate relationship with trying to figure this stuff out but I find it very interesting.
I set the other 3 APU buttons.
APU Start just required the mouse click 164.
The APU Generator worked using your coding with the code 52698.
The APU BleedAir worked using your coding as well with the code 57932. Interesting though, when in detective the test button would only start the BleedAir. I hooked it up to a P8 button anyway figuring I would work on it some more tomorrow and I was surprised to see it worked both on and off. You have to hold the button pushed for a few seconds for some reason to turn it off. Go figure.
Only have a few free buttons and switches left on my GF equipment so might have to go shopping again soon to finish this off!
Thanks for everything!!
Dave
