Import failure
I am having problems importing Rob Ainscough into GIT 2.1.19.5.
The Carenado S550_Citation II.xml imports but throws a lot of errors as it loads each bespoke event for example:
"The Event "BE_LIGHTS_INT_DOME_ON has errored:System.ArgumentOutOfRangeException:Specified argument
was out of range of valid values.
at A.XK.I(String , Boolean)
at A.XK.I (String , String , Boolean , Boolean ), Task will not be loaded , Please check the event in Detective.
Eventually I end up with most of the bespokes available in Detective.
On trying to load Carenado S550_Citation II_GFMCPPRO.xml into the MCP PRO tab I get the following error:
"Failed to load Configuration Data for Device GFDEVHWTYPE_GFMCPRO"
All other configs downloaded such as the J41 etc load into GIT just fine, where am I going wrong ?
regards
glyn
regards
glyn
Hi Glynn,
I suspect that the aircraft has been updated and certain lvars no longer exist. Contact Rob directly to determine what version of the aircraft he built the config for.
