Blanking improvement
Using the new blanking feature I was able to blank the VS display on the FF 777 because when its blanked it goes to -999 , so that was easy to make work.
What I can't figure out is how to blank IAS if for instance VNAV is on. First I tried making a bespoke variable and writing to that with a 1 if the display was off or writing the value of the IAS display to it if it was on, then I tried to display the variable for the light value, I tried using call in the rotary to update the variable whenever there was a change but that didn't work either.
My suggestion is to add a new line to the light display so that you can blank it based on another bespoke variable, so I could create easily a bespoke variable that set to 1 if VNAV was on etc . Actually several of the tubeliners I'm working on have a dataref like display_is_blank etc for the VS and IAS displays.
I would use a Bespoke Variable for the Display.
Set the Bespoke Variable to a non normal value when you want it to blank such as -1 or 9999999. Obviously a Bespoke Event would do this when a certain condition is met. Use further Bespoke Events to change the Bespoke Variable to map to the actual DataRef you want to display via a Set=. You may need to add a Sleep task after the actual Task that changes the DataRef so that GIT catches up and then do the Set= so it's in sync.
Yes, works in exactly the same way.
I can create another action called IAS_MACH_BLANK to handle it all. I'll add it to the development plan.
