X-Plane Crashes On Start With GIT
With the GIT plugin installed in the plugins folder, X-Plane will crash on startup.  If I take the GIT plugin out of the folder, X-Plane will start normally.
I check the Windows Application log and see that there is a conflict with SHLWAPI.dll, which is a Windows system32 file, when the GIT plugin is installed.
Is there something that I need to do to get the plugin to work correctly?  I checked all of my system files and they are working correctly.
Log Name:      Application
Source:        Application Error
Date:          5/1/2016 11:09:39 PM
Event ID:      1000
Task Category: (100)
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      Owner-PC
Description:
Faulting application name: X-Plane.exe, version: 10.4.5.3, time stamp: 0x56bcd7e2
Faulting module name: SHLWAPI.dll, version: 6.1.7601.17514, time stamp: 0x4ce7c9ab
Exception code: 0xc0000409
Fault offset: 0x0000000000013ce9
Faulting process id: 0x1b10
Faulting application start time: 0x01d1a4286729ba79
Faulting application path: C:\X-Plane 10\X-Plane.exe
Faulting module path: C:\Windows\system32\SHLWAPI.dll
Report Id: b037068a-101b-11e6-a355-90e2ba1b5805
Event Xml:
  <System>
    <Provider Name="Application Error" />
    <EventID Qualifiers="0">1000</EventID>
    <Level>2</Level>
    <Task>100</Task>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2016-05-02T04:09:39.000000000Z" />
    <EventRecordID>6119</EventRecordID>
    <Channel>Application</Channel>
    <Computer>Owner-PC</Computer>
    <Security />
  </System>
  <EventData>
    <Data>X-Plane.exe</Data>
    <Data>10.4.5.3</Data>
    <Data>56bcd7e2</Data>
    <Data>SHLWAPI.dll</Data>
    <Data>6.1.7601.17514</Data>
    <Data>4ce7c9ab</Data>
    <Data>c0000409</Data>
    <Data>0000000000013ce9</Data>
    <Data>1b10</Data>
    <Data>01d1a4286729ba79</Data>
    <Data>C:\X-Plane 10\X-Plane.exe</Data>
    <Data>C:\Windows\system32\SHLWAPI.dll</Data>
    <Data>b037068a-101b-11e6-a355-90e2ba1b5805</Data>
  </EventData>
</Event>
