GIT 2.2.4.1 - Strange behaviour with GF-166's
I can't seem to get my GF166's to work reliably.
When I start GIT/P3D the MCP etc initialises but the radios remain off and are not functional(No display or buttons function but the devices show up in the tabs).
 I have to unplug/replug the USB connection , then restart GIT ,  then it will work. Rinse and repeat for the other GF166. but then when I do this the other radio stops working or sometimes they both work.
When I do have 1 working the GF_166_Control_TOGGLE1_2 function doesn't appear to work either.
Tried disabling the GF databridge, running as admin etc to no avail.
I'm almost sure it's not a driver issue because the XPlane version of GIT both radios start and work normally without having to do any of this.
    I can comfirm that the GF_166 control functions are not working.
    As for the other issues, I am not seeing that. I did however have a similar problem some time back which appeared from nowhere. In the end I had to buy extra hubs and separate all my GF166's out onto different hubs. They are notorious for being finicky.
  • I'll try moving them to diff USB 2 ports and see if that fixes it. Weird that it happens right out of the blue. Maybee a stealthy Windows 10 update did something....
  • Moving them around to 2 diff ports seems to have corrected the issue. Still baffled as to why it happened out of the blue like that.
