IXEG 737 MCPPro + EFIS final - Requires GIT 1.4 or later
Now that we can use the IXEG without crashes here's a new version of my profile with EFIS and MCPPro support.
Please let me know if you run into any probs, thanks.
Did you import the Bespoke Events first via Detective?
P.S. The FAQ has the details on correctly importing config files: http://www.pollypotsoftware.org.uk/support/user-guide/goflight-interface-tool-x-plane/33-installation/96-faq-goflight-interface-tool.html
Programed FMC, hit the flt dir left switch, crashed. I do have ver 1.4. In the log it said that it could not load a bunch of 733 data refs.
Hi Rdegle,
Gizmo is a very "crashy" program. I would remove all your plugins except the GIT Plugin. Verify the date of the GIT Plugin xpl files are 16/5/2016 and update to GIT 1.5. Prove that everything works OK, then reintroduce a few plugins at a time until the crashes start and then you will find which plugins are not Gizmo compatible.
I will give it a shot, thanks. Let you know
Ok I will look around to get the right one in xp/resources/plugins
Steve, would you mind sharing your plugin, the oly one I have is dated 5-1-16, still chasing my tail.
Jeff
Rdegle,
If you have multiple versions of XPlane installed the plugin can get installed in the wrong version of XPlane?
Thank you
