ver 1.6.1.0 X-Plane
Steve,
With the Carenado planes I cannot access the menu, left side bar that has the views and options on all their planes I have, nor the auto pilot with the C90.
I just temporary shut down your module when I need to access the Carenado menu.
Just a heads up this happens on my system.
Somehow blocks the mouse from operating the menu items.
Trevor
Trevor
Hi Trevor,
I'll add it to the bug list and look into it.
Hi Trevor,
Replace the GIT Plugin with this version: https://www.dropbox.com/s/5fwng749kd1hdik/GIT%20Plugin.zip?dl=0
Let me know how you get on.
New version works perfect.
Thanks.
Trevor
Hope you have had a nice break away.
Just change of pace for me and gone back to small aircraft and found that the old problem has slipped back into your plugins.
Namely the blocking of the Carenado planes menus and not being able to use the scroll functions.
Yep, you fixed it way back in July but flying the airliners had not noticed till I took out the Small aircraft recently that it is back.
Cheers
Trevor
Hi Trevor,
The fix was made in version 1.6.2.0 which is why you are seeing the problem.
Had the problem with 1.6.5.0 and went back to 1.6.4.0 still had problem, pulled all the files from the resource/plugins, no change. Everything works fine when Git plugin removed.
Loaded clean XP 10.50 and 1.6.5.0 and have had no trouble since, have added most of the plugins back.
Still a few to go but all my Carenado aircraft work perfect now.
Going to put it down to MS Win 7 64 in the meantime.
Cheers
Trevor
