Q400 Download
Life took me away from my hobby for a bit and I see that Slayer has a new Q400 download.
Looking at the .jpg for the EFIS/MCPPRO that the key assignments are the same as mine. I am still
successfully using the previous version and am wondering if updating to the new one is
worthwhile for me?
Somewhere along the way I read something about speeding up the rate at which the knobs on
the MCPPRO could be turned without locking up. Is this in there too?
Should I "fix it if it ain't broke?" :-)
Dave
worthwhile for me?
Dave
Hi Robert,
The "<aircraftname> Vars.xml" is imported automatically when Bespoke Events are imported.
I do not know why Rob included BespokeVariables.xml - perhaps it was from an earlier version where the Vars could not be exported. Unless there is anything in that file it can be ignored, otherwise copy and paste the contents into your own BespokeVariables.xml.
I am not sure what happened, however as a result of having to move my computer and thus unplugging all usb's etc., I seem to have lost the MCPRO and EFIS setups that I had downloaded and imported in to GIT. I also updated to the latest GIT 2_5_1_0 which probably didn't helped matters. So before going ahead with importing I have to delete all the existing bespoke events prior to starting the procedure, correct?
What I am wondering is if I can somehow keep the events that I created myself? I realize that clicking the red X in the bottom right corner deletes everything and I am trying to avoid that. While it might be time consuming can I delete them one by one, so I don't lose the ones I want to keep?? Or, is there an easier way??
Dave
Hi Dave,
If the Bespoke Events are still present, leave them be. Simply load the configs for the MCP PRO and EFIS on the relevant tabs and you will loose nothing.
The bespoke events that are there have no code in them. Is that normal?
Do I have to import the mjcq400.xml if i want to add the GF166 which I didn't have before?
Difficult to know what to do when I don't understand the mechanics of how this works.
Can I manually delete the bespoke events that I didn't create and exit the software to save it, Then start with importing the mjcq400.xml and then do the specific imports in each tab.
Thanks for your help.
Dave
Hi Dave,
If you want to install the GF166 then your best bet would be to manually delete the Bespoke Events which are not yours then run the Import Wizard on the front screen and it will do everything for you - just tick what you want to install.
thank you gentlemen
Only hiccup is that the wizard only gave me the option to select one 166 and it imported the VHF as device 0. The other 166 tick boxes were greyed out.
Tried importing the mjc8q400_GF166-NAV as device 1 on its own, and it populated fields, but didn't bring either of my remaining 166's too life. (Have 3 in total)
Any ideas would be great!
Dave
Hi Dave,
You will have to pick the GF166 device you want to configure on the GF166 tab and then click import and select the correct GF166 config you wish to use.
Been fooling around with it for a few days and no luck. As outlined above, I can't get the second 166 to come to life. I can see that the import worked into device 1 but nothing lights up on my 166.
Have UHF working on device 0 from original import with the wizard.
Any suggestions??
Dave
Hi Dave,
I have just tried it with a clean config for the Q400 as follows:
Import Wizard, selected MCP PRO, EFIS, GF166. Imported all OK and the GF166 Device 0 was picked up as the VHF.
I then went to the GF166 tab, selected Device 1, clicked Import and selected the file mjc8q400_GF166-NAV.xml from My Documents\GoFlight Interface Tool\Temp. Enabled the device and everything was OK.
