x plane interface and airbus a320 jar
I have the fsx interface with pmdg 777 and all works ok with the goflight MCPPRO. With X PLANE the installation and registration appeared fine
but when I load X plane the MCPPRO does not turn on or in spite of three green lights work with the airbus.
Could I please have some suggestions
TUROSS
TUROSS
Unlike the 777, there is no inbuilt support for non standard aircraft. No-one has built a config for the a320 jar as yet. You could try clicking the FS Default button on the MCP PRO tab and then enable the MCP PRO and see how much works with it.
Anything that doesn't work, you will need to use Detective to identify and build Bespoke Events.
