Install issues
I just purchased the fsx-steam, p3d and xplane versions of the goflight interface tool. I went to install the xplane version first. I installed the downloaded file. Then it asked for the user key, which i copied and pasted into the box. I had an internet connection and pressed the button to continue the install. It failed at that point stating error 203, the user key is wrong, or wrong order. I copied and pasted it. There is no way it could have been messed up. I do not know what to do from here. I did not try to install the other two yet until I finish with the first one. Please respond asap. Thanks in advance.
Confirmed problem at our end. It should work OK now.
