can't get it to work
The only way I can get my GF-MCP Pro to work is to uninstall this pollypot software.
I don't know where to begin to ask for help.
Have you followed the installation instructions: http://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/14-installation.html
It's very important that the MCP-PRO in GFConfig is set to Compatible Add-On.
Perform the following test:
- Load up the Default Beech Baron so that the Virtual Cockpit is showing. The MCP PRO should be blank or show dashes. If it doesn't you have not configured GFConfig correctly.
- Start GIT, go to the MCP PRO tab. Enable the device, click the FS Default button, then quit GIT.
- Now restart GIT - does the MCP PRO work with the Beach Baron OK?
