Goflight error during start up
Hi all
Got an error message during starting up goflight IT.
Any idea? Using win 7 pro and fsx spe.
Greetings
Marcel
Hi Marcel,
What was the error message?
Make sure you are using these GoFlight Drivers: https://www.dropbox.com/s/qj9l968zsp7313p/GFConfigSetup_2_26_5.zip?dl=0
C:\Program Files (x86)\GoFlight ).
Got the next "windows message "Go flight interface tool doesn't work
Can you try renaming My Documents\GoFlight Interface Tool and try again. Has it ever worked?
Doesn't matter wich name? Is " My Documents\GoFlight Interface_a320 '' ok?
I renamed to Goflight Interface. Now it doesn't do anythin
When you say is doesn't do anything - is the status screen visible?
Has it ever worked?
Did you get the license key screen and PMDG SDK license screen on first use?
Did you install GIT into the same directory as the GoFlight drivers?
Can you try copying the file <your Steam directory>\common\FSX\SDK\Core Utilities Kit\SimConnect SDK\lib\managed\Microsoft.FlightSimulator.SimConnect.dll into the GIT folder.
Problem solved. programs works.
Marcel
