GIT 1.6.4.0 XPX problems
Hey Steve. I updated to 1.6.4.0 but now I'm getting a bunch of errors with my IXEG profile and GIT is removing parts of the bespoke events so I can't actually see what was in there before unless I open the exported .xml files I can't seem to figure out what is wrong now when it was working before. Tried removing the profile and reimporting etc but the result is the same.
Has there been a recent IXEG update that may have changed the DataRefs? I'm asking because the .4 release was only some minor changes that did not alter the save/load/import/export code at all.
If they are listed in Datarefs.txt in the aircraft directory can you email me the file so I can see what happens when it loads.
PS: Also check the log and see if those Datarefs are causing an error. If so, give me the error code.
Is the Flight Factor 777 giving you green ticks against DataRefs.txt etc and also do you have multiple X-Plane installations/copies?
I have followed the code through and it appears the DataRefs.txt has some random spaces at the end of some of the lines. This is triggering a bug in the code which I have now fixed.
I'll release a new version in a hour or so for you to try.
Ok Steve, new version is available for download from your account. Let me know how you get on.
