GIT 1.6.4.0 XPX problems
Hey Steve. I updated to 1.6.4.0  but now I'm getting a bunch of errors with my IXEG profile and GIT is removing parts of the bespoke events so I can't actually see what was in there before unless I open the exported .xml files I can't seem to figure out what is wrong now when it was working before. Tried removing the profile and reimporting etc but the result is the same.
  • edited August 2016
    This is the code from the .xml file:
     <Event
            Name="GIT_EHSI_pt_WXR_button"
            ID="8"
            Backgnd="False">
            <Task
              ID="0"
              Type="Label"
              Name="ON" />
            <Task
              ID="1"
              Type="If"
              Var="ixeg/733/ehsi/ehsi_wxr_pt_act"
              Operator="EQUALS"
              Value="0" />
            <Task
              ID="2"
              Type="Set"
              Data="1" />
            <Task
              ID="3"
              Type="Label"
              Name="OFF" />
            <Task
              ID="4"
              Type="If"
              Operator="EQUALS"
              Value="1" />
            <Task
              ID="5"
              Type="Set"
              Data="0" />
          </Event>
    Has there been a recent IXEG update that may have changed the DataRefs? I'm asking because the .4 release was only some minor changes that did not alter the save/load/import/export code at all.
    Something strange is going on because GIT can no longer see the datarefs I had referenced in those events that are erroring.
     But if i use DRT or DRE the datarefs are still there,  yet they do not show in detective with the "monitor DRE private datarefs enabled". Specifically their datarefs that end with a _act (actuator dealing with the button animation etc ) are invisible to GIT and it throws an error because it can no longer find them.
    Keep in mind I wasn't using DRT or DRE at the same time. Only to verify if the datarefs were stiill present because GIT can no longer see them.
    I'm stumped.
    If they are listed in Datarefs.txt in the aircraft directory can you email me the file so I can see what happens when it loads.
    PS: Also check the log and see if those Datarefs are causing an error. If so, give me the error code.
    here is the log:
    16:58:05 GoFlight Connection Starting.....
    16:58:05 X-Plane Connection Starting.....
    16:58:06 GoFlight Connection Started
    16:58:08 GIP: Pipe Connect Failed!
    16:58:11 GIP: Pipe Connect Failed!
    16:58:14 GIP: Pipe Connect Failed!
    16:58:17 GIP: Pipe Connect Failed!
    16:58:18 X-Plane Connection Started
    16:58:18 Aircraft Connection Starting.....
    16:58:19 Aircraft Connection Started
    16:58:19 Synchronising Switches & Selectors .....
    16:58:19 Synchronising Switches & Selectors: Waiting for X-Plane .....
    16:58:32 X-Plane: Event Received: Aircraft Loaded/Flight Loaded
    17:02:06 X-Plane: Event Received: Aircraft Loaded/Flight Loaded
    17:02:07 LvarNamesUpdated!
    17:02:07 Creating Bespoke Vars
    17:02:07 Bespoke Vars Created
    17:02:07 Importing Bespoke Variables
    17:02:07 Bespoke Vars Assigned, Importing Bespoke Events
    17:02:07 Bespoke Events Temp Imported
    17:02:08 Bespoke Events Imported
    17:02:08 Loading Aircraft Settings
    17:02:08 GetXMLConfigData
    17:02:08 GotXMLConfigData
    17:02:08 Loading Power
    17:02:08 Loading MCPPRO
    17:02:08 Loading EFIS
    17:02:08 Loading P8
    17:02:08 Loading T8
    17:02:08 Loading RP48
    17:02:08 Loading MESM
    17:02:08 Loading WP6
    17:02:08 Loading LGT
    17:02:08 Loading LGT II
    17:02:08 Loading GF46
    17:02:08 Loading GF45
    17:02:08 Loading TQ6
    17:02:08 Loading DIO
    17:02:08 Loading GF166
    17:02:08 Loading SECM
    17:02:08 Loading Joysticks
    17:02:08 Clearing Displays
    17:02:08 Reset Data
    17:02:08 Aircraft Settings Loaded
    17:02:08 Calling Aircraft Changed
    17:02:08 Aircraft Changed
    17:02:08 XPlane: Event Received: Sim State 1
    17:02:36 Synchronising Switches & Selectors Complete
    17:02:59 GIP: Send Message - Unexpected Reply Messsage
    17:02:59 GIP: Unable to Monitor DataRef ixeg/733/lighting/light_main_pi - 20002
    I don't use that dataref it can't monitor in the log , the log is truncating the full dataref name which is listed in the DreDatarefs.txt. The full name of the dataref is ixeg/733/lighting/light_main_pilot_side
    Another weird thing is on the status page of GIT the DataRefs.txt  and DREdatarefs.txt have the red X next to them even though the files are there
    here is the datarefs.txt
    Is the Flight Factor 777 giving you green ticks against DataRefs.txt etc and also do you have multiple X-Plane installations/copies?
  • It's a single install. Yes the datarefs.txt does show the green checkmark for the FF 777, no errors onb that aircraft.
    I have followed the code through and it appears the DataRefs.txt has some random spaces at the end of some of the lines. This is triggering a bug in the code which I have now fixed.
    I'll release a new version in a hour or so for you to try.
  • Ok Steve, new version is available for download from your account. Let me know how you get on.
  • Great. I'll give it a try and report back. Thx for the support.
    You can mark this solved.
    Everything is working properly again, checks working on status screen and all BE's loading properly.
    Thanks again, have a good holiday.
