Mcp pro screens blank and no lights with NGX
Not sure what is going on, just bought the interface yesterday
Brand new built computer
Fresh p3d install
Fresh NGX install
GIT loaded up at first not working and had a yellow dot in the middle sim connect section
Reinstalled
It worked one time perfect , nothing changed since.
Now no matter what I do (is there a correct order for loading up the softwares?), the mcp controls everything in the NGX perfectly but all the displays go blank the instant the flight loads. It shows dashes then all zeros then blank.
GIT shows three green
Any ideas?
Have you set the MCP PRO to compatiable add-on in GFConfig.
You need the very latest version of the NGX (SP1D or above). GIT only works with the later versions of the NGX as PMDG changed the SDK.
Also read the FAQ entry "My MCP PRO or MCP Advanced is not updating its display (just showing zeroes)" here: http://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/70-faq-goflight-interface-tool.html
This really does sound like you are using the older NGX version. If you really are using SP1D or higher I would suggest an uninstall and reinstall of the NGX.
Support for the NGX via GIT has been around for years. Any problems are always the result from the issues listed in the FAQ. If there was a new issue with P3D and the NGX I would have several hundred users complaining by now.
Send me your version number from the NGX so I can confirm you have the latest.
You are running P3D v3.2+
1) One of the following:
a. FSX SP2
b. FSX Acceleration
c. FSX Gold
d. Prepar3D 3.2+
e. FSX Steam Edition
Your NGX version is 1.10.6461?
The only thing I think of now is that its a security/access rights issue. Try running GIT and P3D as Administrator.
Actually, just reading the thread again, it did initially work so I wonder if your config files are corrupt. Try renaming My Documents\GoFlight Interface Tool and try again.
Excellent news. Don't worry about the Simconnect light - the NGX uses client data instead of standard Simconnect variables/data so it will flash rarely.
