Joysticks not working
I just finished building a new pic with win 10 pro. I installed the goflight and GFIT programs and tried to calibrate the joystick. The joystick enabled ok but when I click configure axis none of the sliders move at all and appear kind of greyed out? This is true before and after I select the sim axis to control and click the calibrate button? I know it should work because I have the exact same setup on my win 7 pc and the joysticks work fine.
Is the some setting in win 10 I need to change? All the joystick axis work in the Windows game controller window. Also I can assign buttons in GFIT and they work.
It is just the axis assignment and calibration that is not working.
Terry
Hi Terry,
I've been looking into this and I think I now know what the problem is. I'll pick the issue up with you after my holiday.
Hi Terry,
End of the week if things go to plan.
This issue should now be resolved in 2.6.0.0
Assuming you have calibrated the joysticks in Windows, can you rename My Documents\GoFlight Interface Tool so that GIT starts clean - I just want to see if an erroneous value has entered your config.
The limit values will vary and will change. When you click calibrate the limits shown are recorded within the software and used to calculate what is sent to FSX. The limit values show what is being read in and not what you have calibrated the joystick too. If you want to check them, open up the xml file in My Documents\GoFlight Interface Tool and located the aircraft section concerned and then the joystick device and the calibrated limits will be shown (after you have quit GIT so the settings are saved).
I'm not sure about the Vjoy. Lets start with giving me the Vjoy device name as shown in your GIT log.
No Terry. You are never going to get two axes outputting exactly the same values and over time as they get worn the situation will get worse.
Make sure you have properly calibrated the axes in Windows, then go through the calibration process in GIT (http://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/19-operating/25-configuring-joystick-devices.html). If the levers differ slightly and it creates problems in the sim, you can recalibrate, but click and drag the limit sliders to add some artificial slack so they sync better.
When you hit the calibrate button the axis limits are recorded - you then ignore what is showing up on the slider subsequently and for different axes - only the axis shown has its calibration settings set when Calibrate is clicked.
No worries. I'll come back to you on the vJoy as I made need you to test out a few things before we solve it.
Hi Terry,
Can you copy and paste from the log everything listed about the Vjoy.
Ok thanks, I'll review the code tomorrow and see what is breaking in Windows 10.
No. I can't find what is wrong. It did work in the previous Windows versions?
Hi Terry,
That will help a lot if I can install the software. I'll try it.
In theory GIT should, but I have had to code detection of devices to certain ones as it was incorrectly picking up wrong devices and thus crashing GIT for some people.
Hi Terry,
I think I must have the wrong vJoy website as I have just tried GIT with this and it works fine: http://vjoystick.sourceforge.net/site/index.php/download-a-install/download
Can you let me know what you are using.
