XPlane: SSG Boeing 747-8i MCPPro+EFIS
This is my profile for the SSG 747-8i
If you have any questions or need help just ask. Please look at the readme and/or the FAQ section here if you have any questions on how to install.
Notes:
On the EFIS I'm limited by the range switch so the ranges are what you see available on the MCPPro as it's easiest to figure out but I included the other ranges in the bespoke events if you want to swap one out to your liking.
The Baro has push to turn Function so to select IN/HPA push the rotary in and while holding it iin rotate it , a quick push will set STD
Course rotaries are disabled as course is set through the FMS for this aircraft but the displays are still active and reflect correctly.
Is this for the freeware or payware version as someone has emailed me saying they are having trouble getting it to work.
Great. I'll ask him to post the issue here as I don't have the payware SSG so can't really help him.
I have a problem in the activation of added file
To 748 aircraft
SSG B748-Series_v1.4
GIT XPlane
X-PLANE 10
Hi Awaisi88,
What language are you using in Windows?
You can't be running English as the pictures you have shown show Arabic on the buttons. I need to known exactly what language is running so I can debug the program against that language to resolve the issue.
I'll do some testing using Arabic and come back to you.
Are you saying the issue is resolved now?
