GIT X-Plane not finding/parsing all datarefs
Hey Steve,
I've been trying to create a profile for the Flight Factor 757 off and on since the X-plane version of GIT came out and have given up a few times. The issue I'm running into is the dev never bothered to include a list of datarefs. The problem is detective can't see most of the private datarefs even with the "Monitor DRE Private datarefs" box checked
If I use DatarefTool I can see these datarefs and manipulate their values and it works. GIT should be able to sniff these out too but it can't. I suspect there is something getting missed where GIT is searching for the datarefs or isn't parsing them all. The ones that are giving me fits in detective start with a "1-sim/AP/" etc
I also tried manually putting a few datarefs into the datarefs.txt file, then they show in detective but if I try to use the dataref nothing happens .
I know for certain that the program checks for a number at the beginning of the extracted Data Ref and removes it because some aircraft do not have a space or tab etc in between a value and a dataref.
If all the datarefs with a number have a hyphen after the number, I can build in an exception to the rule and allow them through?
This issue should now be resolved in 1.7.0.0
Hi Steve have you managed to get time for the profile yet ??
If you have I wouldn't mind a copy, fed up trying this afternoon.
