XPlane: SSG Boeing 747-8i MCPPro+EFIS
This is my profile for the SSG 747-8i
If you have any questions or need help just ask. Please look at the readme and/or the FAQ section here if you have any questions on how to install.
Notes:
On the EFIS I'm limited by the range switch so the ranges are what you see available on the MCPPro as it's easiest to figure out but I included the other ranges in the bespoke events if you want to swap one out to your liking.
The Baro has push to turn Function so to select IN/HPA push the rotary in and while holding it iin rotate it , a quick push will set STD
Course rotaries are disabled as course is set through the FMS for this aircraft but the displays are still active and reflect correctly.
«13
