Device Qty mismatch error
Suddenly I see this error
The hardware of the following type GFP8... and few others  has less devices connected to the system than configuration file indicates. .continuing will result in the missing device  in config data being lost as well as potentially loading the remaining devices with different device configs. Click ok to continue or cancel to Quit [Recommended]
if I say OK, it at least load the  GF MCP Pro
  • The issue is solved.. I unplugged one of the hubs connected to another hub and connected it directly to the PC
