nothing happens
I am going through initial setup and configuration. I have 2.1 installed ok and seems to run ok. I have set GFConfig for p8, t8, 166, 46, 48 and mesm to nothing. When I am in GIT for say T8 trying to turn landing lights on and off, nothing happens in p3d. Switch event shows on, landing_lights_on, switch_action onoff. Any ideas?
Assuming you are using a T8 switch or similar, and the aircraft isn't the NGX or 77X, leave the event action as NOTHING. You will also need to add the landing_lights_off event to the OFF action.
