GoFlightInterfaceToolSE_Setup
  Just downloaded and installed  SE version  2.1.14.2.   Startup with the PMDG NGX results in a "Prepar3d ini file not found PMDG options file cannot be checked/updated" error.    Previous version performed as designed....
Robert
  • P.S.  Prepar3d does not have a check mark in settings.
    Robert
  • Hi Robert,
    I'll look into it.
  • edited July 2015
     All is well here again....I have P3D and FSX SE installed on separate drives.. Both the P3D Tool and the FSX SE tool are installed in the GoFlight main folder. I had temporarily uninstalled the PMDG NGX from P3D  prior to installing the SE 2.1.14.2 Tool.....Even though P3D was not selected in the SE Tool settings, It was still looking for the Prepar3D ini file.   After reinstalling the PMDG NGX, Both the SE and the P3d Tool are functioning correctly.
    Best regards
    Robert
    I'm running P3Dv3.4.9 and the latest GoFlight drivers and GIT. After a while I wanted to fly the PMDG 737NGX (also latest version) and everytime I start GIT I become the same message "Prepar3d ini file not found, pmdg options file cannot be checked/updated". If I click "OK" the MCP Pro works without problems.
    Any ideas what is causing this message?
    Martin
  • Hi Martin,
    On the Settings tab of GIT, untick Enable for PMDG/Prepar3D.
    I missed this option.
    Thank you,
    best wishes
    Martin
