GIT Lock Ups
The GIT I've had working with Win 10, X-Plane 10.51 and the IXEG 737, in the past couple of days. Whilst the software is great I'm having increasing problems with lock ups.
Without getting into too much details for the moment, below is a copy of the log file. I'm thinking the last line is significant.
I am running the latest GoFlight drivers 2.26.5
12:00:36 GoFlight Connection Starting.....
12:00:36 X-Plane Connection Starting.....
12:00:37 X-Plane Connection Started
12:00:37 Aircraft Connection Starting.....
12:00:37 X-Plane: Event Received: Aircraft Loaded/Flight Loaded
12:00:37 GoFlight Connection Started
12:00:38 Aircraft Connection Started
12:00:38 Synchronising Switches & Selectors .....
12:00:38 Synchronising Switches & Selectors: Waiting for X-Plane .....
12:00:40 LvarNamesUpdated!
12:00:40 Creating Bespoke Vars
12:00:40 Bespoke Vars Created
12:00:40 Importing Bespoke Variables
12:00:40 Bespoke Vars Assigned, Importing Bespoke Events
12:00:40 Bespoke Events Temp Imported
12:00:40 Bespoke Events Imported
12:00:40 Loading Aircraft Settings
12:00:40 GetXMLConfigData
12:00:40 GotXMLConfigData
12:00:40 Loading Power
12:00:40 Loading MCPPRO
12:00:40 Loading EFIS
12:00:40 Loading P8
12:00:40 Loading T8
12:00:40 Loading RP48
12:00:40 Loading MESM
12:00:40 Loading WP6
12:00:40 Loading LGT
12:00:40 Loading LGT II
12:00:40 Loading GF46
12:00:40 Loading GF45
12:00:40 Loading TQ6
12:00:40 Loading DIO
12:00:40 Loading GF166
12:00:40 Loading SECM
12:00:40 Loading Joysticks
12:00:40 Clearing Displays
12:00:40 Reset Data
12:00:40 Aircraft Settings Loaded
12:00:40 Calling Aircraft Changed
12:00:40 Aircraft Changed
12:00:41 XPlane: Event Received: Sim State 1
12:00:49 BespokeEventProcessor: 'A. ' does not contain a definition for 'ForecDataRefreshAlternative'
Cheers
Graham McAllister
  • edited October 2016
    Hi Graham,
    Thanks for high-lighting this. This is new code to fix an issue in GIT for FSX/SE/P3D that is obviously impacting the X-Plane version of GIT. It looks like a simple spelling mistake - Forec.... instead of Force...
    I'll try and get a fix out later today.
  • I imagine this will require a new download at some point? 1.7.0.1? :-)
    Cheers
    Graham
  • Hi Graham,
    Updated version is now available for download. Let me know if it fixes the problem.
    It appears to be the same. Here is the current log.txt
    02:01:37 GoFlight Connection Starting.....
    02:01:37 X-Plane Connection Starting.....
    02:01:38 X-Plane Connection Started
    02:01:38 Aircraft Connection Starting.....
    02:01:38 GoFlight Connection Started
    02:01:38 X-Plane: Event Received: Aircraft Loaded/Flight Loaded
    02:01:39 Aircraft Connection Started
    02:01:39 Synchronising Switches & Selectors .....
    02:01:39 Synchronising Switches & Selectors: Waiting for X-Plane .....
    02:01:41 LvarNamesUpdated!
    02:01:41 Creating Bespoke Vars
    02:01:41 Bespoke Vars Created
    02:01:41 Importing Bespoke Variables
    02:01:41 Bespoke Vars Assigned, Importing Bespoke Events
    02:01:41 Bespoke Events Temp Imported
    02:01:41 Bespoke Events Imported
    02:01:41 Loading Aircraft Settings
    02:01:41 GetXMLConfigData
    02:01:41 GotXMLConfigData
    02:01:41 Loading Power
    02:01:41 Loading MCPPRO
    02:01:41 Loading EFIS
    02:01:41 Loading P8
    02:01:41 Loading T8
    02:01:41 Loading RP48
    02:01:41 Loading MESM
    02:01:41 Loading WP6
    02:01:41 Loading LGT
    02:01:41 Loading LGT II
    02:01:41 Loading GF46
    02:01:41 Loading GF45
    02:01:41 Loading TQ6
    02:01:41 Loading DIO
    02:01:41 Loading GF166
    02:01:41 Loading SECM
    02:01:41 Loading Joysticks
    02:01:41 Clearing Displays
    02:01:41 Reset Data
    02:01:41 Aircraft Settings Loaded
    02:01:41 Calling Aircraft Changed
    02:01:41 Aircraft Changed
    02:01:42 XPlane: Event Received: Sim State 1
    02:01:50 BespokeEventProcessor: 'A. ' does not contain a definition for 'ForecDataRefreshAlternative'
    Assuming I did things correctly downloading the new files and placing those in the Documents/GoFlight Interface Tool folder? I then ran the GIT, followed by Detective deleting the old Bespoke events, then Importing Besoke events B733.xml. I then
    enabled my MCPPRO, EFIS, P8 and T8 importing the new B733_GFMCPPRO.xml and B733_GFEFIS.xml.
    Cheers
    Graham
  • You need to go into My Account and download a new version of GIT.
    All done and all appears well. I can no longer get the error and the switches and dials continue to work.
    Cheers
    Graham
