Hi Paul,
I'll get a debug version out to you tomorrow. Apologies for the delay, but I needed to get this new release out.
By the way it has an option for disabling Joystick support which will work around the joystick problem until we resolve it.
Hi Paul.
I done a new debug version for you:
https://www.dropbox.com/s/l1ovy7qa84qvrq9/GIT%20Debug.zip
Hi Paul,
I would have liked to get to the bottom of your joystick issue to improve the software's reliability.
I'll need to look at the GF45 code to see what's going wrong. I don't own a GF45 so I work on the code blind, so bear with me.
There is a bug in the GoFlight SDK regarding different versions of the GoFlight drivers and the MESM. It looks like the integration of the generic code has not passed on the bug fix. I'll take a look.
Hi Steve
I'll run the debug tomorrow morning but I still have problems posting on the forum as your site is so slow from Japan. My connection speeds are around 500MB/s (tested) on a 1GB connection so I don't think it's my end. Is it possible to send you files via email or via dropbox?
Do I need to uninstall 2.0.823 or just overwrite it?
Paul
Hi Paul,
The website is having problems due to the hosting company so its not your end. You can use dropbox if its easier.
Yes uninstall and make backup copies of all your settings files.
Hi Paul,
I need you to run it with the joystick plugged in that's playing up.
Hi Paul,
Thanks for this. Its weird thought because its failing where I expected it to, but last we tried it didn't fail there! Very odd.
I'll flesh out debug messages in that area of the code for you try again to give me detailed output.
Hi Paul,
You bug report on the GF45 button not working has me scratching my head because I understood the GF45 does not have buttons, only the GF46 has buttons? Can you confirm.
Hi Paul,
I've fixed the ignition problem with the MESM, but are you now saying the LH engine selector is faulty as well?
Hi Steve
It's the same problem I had with the NGX. See my earlier post on this forum. My MESM is brand new so I don't suspect it as the problem. I'm using GF v2.22
Paul
Hi Paul,
Goflight are sending me a MESM and GF45. Hopefully they will be with me this week or early next week. I can then code and test for them properly instead of doing it blind.
Hi Steve
GoFlight have sent me a test programme for my MESM. I'll let you know if it's faulty or not after I test it tonight.
Paul
Thanks for letting me know.
Hi Paul,
When you are next at your machine, a new debug version is available for you to try. Remember I need you to have the Cyborg Joystick plugged in when you run it.
