MJC Dash 8 Pro v1.018e / GIT 2.6.0.0 Problem
Hi, until yesterday all functions of my MCP Pro and EFIS worked great. Suddenly the Efis doesn't work and the buttons at the MCP Pro also doesn't work. The rotaries and digits at the MCP Pro are ok.
I deleted all Bespoke events and reimportet the actual profile with the profile wizard. But I can't bring the Efis and knobs at the MCP Pro to work.
Is/Should the profile for the Dash be included in the GIT like the PMDG profile?
Any idea what could cause this problem?
Martin
Martin
Hi Martin,
Did you change/install anything on your system?
sorry, it's me again. A few months ago I had problems with the MJC Dash. Until yesterday all was ok. I've nothing installed the last days. The only thing I remember was a flight, I quit because I couldn't move the gear up. This was a failure of the Dash. The only thing I did, was to change the cockpit state at the Control Panel of the Dash to Boarding. Meanwhile I tried to set the CP back to default and installed the profile again with the Import Wizard.
Best wishes,
Martin
Try renaming My Documents\GoFlight Interface Tool in case the config files have got corrupt. Then reimport using the wizard.
renaming and reimport is ok, but there is one problem I notice again.
I must load the Dash direct without loading another aircraft before. If I load a standard flight with a P3D plane and then the Dash I get those failures "The Event "MJC_ADC_BARO_L_CW" has Errored. and this message I have to click "Ok" for every single bespoke event. After this I have to delete all events for the Dash in Detective, close P3D and GIT and reimport all again. A very painful problem.
But I can prevent this problem if I start P3D, load the Dash at the selection screen and start at the airport I want. After this I normally start GIT and had never a problem with any plane.
This messages only appear if I load another standard plane and then the Dash. It don't matters wether I load GIT before P3D or after. And this problem occurs only with the Dash. With the A2A planes I never had this problem.
Hope you can follow my bumpy explanation. ;-)
Martin
Hi Martin,
That sounds like a bug to me. I'll investigate.
