MCP PRO and LGT issues with new Prepar3D installation
Hello to all!
I did search for an answer, unfortunately (and obviously) unsuccessfuly.
"Almost" everything works fine with the new PMDG B737NGX installed in the new Prepar3D.
The MCP PRO buttons/rotaries work, as the windows on the sim's MCP panel change properly and the LED button lights, light up when they should. But, the windows on the GF MCP PRO all show "zeros" and do not change with rotary action and, the LED's of the buttons do not light up when they should.
The LGT (that I only use for gear lowering and retracting), only moves the sim's lever to the "off" (middle position). In other words, if the gear is up and I lower the LGT's lever, the sim's lever (which was up) goes down to the middle position. The reverse happens if the gear is down.
All was working well in FSX (I have both sims on one computer). All the other buttons and rotaries that I assigned in FSX are being properly recognized by P3D.
I am at a loss, on how to proceed next to diagnose what might be happening.
Thank you for any help!
Roberto
