X-Plane 11 and GIT feedback
So I've spent a little bit tinkering with the XP11 beta:
GIT works fine as expected as well as my profiles for payware aircrafts
The problem I'm having is with the new default aircraft.
While the old stock datarefs do partially work they don't fully work(for instance A/T arm may work, the animation and light in the VC don't)
I need to use the new Laminar datarefs for their respective aircrafts but they ALL seem to be write protected or GIT can't manipulate them. I can't even get the commands to work. I've also tried with Dataref tool and Dataref editor to no avail.
I know it's beta but I have a sinking feeling someone at Laminar will just end up leaving all the datarefs for the default aircrafts on lockdown.
Again I'm not 100% sure it's a XP11 or GIT problem but intuition says it's a Laminar problem, not sure if I should file a bug report over there or not.
I have the purchased version of XP11 beta. I fully understand it is beta. I was going to partially make the switch from FSX/P3D to XP10, but really hated the UI and I decided against it. But XP11 is really looking nice.
Anyway....cutting to the chase. I don't presently own the GIT software for XP. But as it is currently written, will it work with XP11 and the default aircraft?
I'm easing into XP and most likely will pickup some payware aircraft at some point. My favorite on the P3D side of course is the PMDG 737. So will be looking at what is similar on the XP side at some point.
Anyway, thank you for your time.
Jerry
Hi Jerry,
It sounds like the GIT plugin is not running. The installation program has not been updated to detect XP11 so it probably has not installed it (you should have been prompted to confirm its location during installation). Check the resources\plugins directory and see if you can see a GIT plugin directory which should contain subdirectories with .xpl files.
Yes, I can send you the plugin and you can copy and paste it into the correct directory.
Guys,
An X-Plane 11 compatible version of GIT will be released shortly.
Version 1.8.0.0 of GIT now supports X-Plane 11.
