P3D3.4 crashes with PMDG Aircraft
Gentlemen,
formerly only rare problems, but on my new PC system (P3d v3.4, Win10/64) P3D crashes immediately -and ONLY- after complete initialization of PMDG aircraft (737NGX, 777) and GIT without any message. All drivers and software are latest version. No simconnect problems, it works normally with any other plane (A2A, Realair etc.), no issues with sceneries. Sorry if I'd not found another thread about that. The registry item in Layers is deleted. Maybe there is any common cause or workaround? Thanks in advance for your assistance,
kind regards
Fritz
Try changing the load order of the GIT plugin in dll.xml. Are you running the very latest version of the NGX? If you have a MESM make sure you are using GoFlight Drivers 2.26.5
