GoFlight Interface Tool 1.8.0.0 for X-Plane
Hello,
Might someone be able to tell me how do I update my XP interface tool to 1.8.0.0? I currently have 1.4 version.
Thank you,
Scott
Hi Scott,
Login to your account, and go the to the Download tab next to your Orders and re-download the software.
Hi Scott,
Auto configure both the GF166's by pressing the NAV button for each device. For the GF166 NAV1, remove all the events and datarefs relating to switching between NAV1 and 2.
For the GF166 NAV2, change any NAV1 event and dataref to the NAV2 equivalent and remove anything else not needed.
Steve,
Thanks.
"Auto configure both the GF166's by pressing the NAV button for each device" Please correct me here as I am going from memory here but I believe that when I configure the GF166 a prompt comes up on the screen and asks if I want to go to default settings? Do I click yes? or no...
"remove all the events and datarefs relating to switching between NAV1 and 2".
Not sure how to do this - please explain.
Regards and thanks! Scott
Hi Scott,
You must have the plane loaded that you wish to make the changes too. Then click the COM button and answer Yes. After that choose each Input Event in turn and look at the events and datarefs displayed. Simply change or select None where applicable.
