747 V3 dome light? How to clear an mistaken entry?
The EVT_OH_DOME_SWITCH ... trying to map it to a T8 but without much success, it'll turn ON but never turn OFF - tried all switch actions.
But more important, how do I "clear" and entry in the Switch Event (other than manually editing the xml files)? Example, suppose I make a mistake with the Switch Event ON and enter "toggle_Cabin_Lights" but I changed my mind and don't want any entry for the switch ON. There used to be a _NO_EVENT, but that's not available for the PMDG - any hints?
UPDATE: found it "BLANK"
EDIT: there appears to be two identical EVT_CDU_R_START and EVT_CDU_L_START ... unrelated, but is there a file I can search thru to quickly ID PMDG supported events? The scroll and search process can get pretty time consuming.
Cheers, Rob.
Hi Rob,
All the events are listed in the .h file in the SDK directory. Goto <flight sim dir>\PMDG\<aircraft>\SDK.
I'll look at adding them to the website soon.
It may be possible. In the meantime, let me know what Cluster events you need and I will add them. They have always been driven by customer demand in the past.
I dont have any PMDG aircraft yet, but I do write my code in a similar fashion as discussed by Rob.
I create BEvs for each switch or button in an aircraft. If there are multiple switches or buttons for a similar activity (Left Landing Lights, Centre Landing Lights, Right Landing Lights), I create a BEv for each.
I then create, what I call a MACRO BEv (and I name it with MACRO too), which calls multiple BEv's, and I assign that MACRO BEv to the GF switch or button.
Having the Detective Screen avail, with the Events and LVar Toggle buttons disabled (if that's whats required) would be very useful.
There may be some standard functions, such as programming FSX/P3D default radio functions that may still be needed, even with PMDG aircraft,and not having access to the Detective screen to write BEv's for default actions might also be limiting.
This should help you guys out where Detective is not available. See here for guide: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/43-lua.html
