GIT X-Plane: No longer functioning
I'm flipping between x-plane 10 and 11 at the moment and today GIT has stopped functioning. The utility launches and the MCPPro starts but with all zeros, it doesn't respond to the controls. I have partial functionality with the EFIS. I have tried reinstalling the program v1.8.0 and even going back to 1.7.2 but nothing changes. I think something may have become corrupted that is not getting replaced with a reinstall, is that possible. I can't think why it has stopped working. I have a screenshot, it looks to me like there are a lot more red X's than before though I can't be sure. I have loaded and reloaded the x737 config without success.
Your config file may have become corrupt. Try renaming the My Documents\GoFlight Interface Tool directory, start GIT, then reconfigure as necessary.
Not sure what it could be then. It may be some disk corruption that has damaged X-Plane or Windows. Try running GIT and X-Plane as Admin. Are you sure you have installed anything else, particularly a plugin?
Are there other hidden files that I can try to remove and then do a complete reinstall?
C:\Users\<your login name>\AppData\Local\PollyPot_Software
C:\ProgramData\GoFlight Interface Tool XPlane
Both are hidden directories. Clear out both and My Documents\GoFlight Interface Tool.
Uninstall GIT, make sure it has gone completely including the plugin in both X-Plane installations. Reinstall GIT
PM me your email address used on your order so I can reset the activation count.
If it is the SSG 737, check that you are running the correct version of the GIT config files for the version you have. Slayer did two versions 1.4 and 1.5 for the relevant versions of the x737. Both are available from Downloads.
Something seems to be happening during the import function. I am getting different versions of the DREDataRefs. The file (attached) DREDataRefs1 looks more likely to be correct but is getting overwritten with DREDataRefs2 on import. I have renamed these files for comparison, they are normally DREDataRefs.
Yep, the one in Slayers config appears to be wrong. Remove it and copy your version into the Aircraft directory.
If you import the config again, make sure you remove the DRE data refs file from the zip before importing.
EIther way, perhaps Slayer could take a look at it.
In version 1.8, the code was changed to over-write any existing dataref and command files with the ones in the config to ensure everything was the same, as some people had issues with incorrect files. This has obviously had the knock on consequence of showing up faulty files in the downloadable configs.
