newest version and new computer clean install
I'm running a clean install of p3d v3.4 on a brand new pc and just installed the latest git. I show the aircraft loaded but a red light, simconnect yellow and goflight is red but showing all my hardware. I downloaded the current goflight software. When i try to close the git it freezes and requires task manager to end the process. I have uninstalled the GIT and reinstalled it along with removing the dll entry with no change. The error on the log tab is the duplicate_ID. I had loaded P3d with a default aircraft and it seemed to be working. I was able to enable devices but shortly after it locked up.
Any help would be great.
-Justin
-Justin
Hi Justin,
If you have a MESM attached, you need the version of the GoFlight drivers listed in Yellow at the top of this forum. Make sure GFDev.dll is also in the GIT directory.
The last person who had a similar issue reinstalled .NET Framework. Check the GIT system requirements as it uses 2 versions of .NET
