PMDG 777
I tried using the GF PMDG NGX settings with the new T7.  No Go.  Do I really have to set all my hardware up again for the T7?
Gnacino
  • edited November -1
    Hi Gnacino,
    The T7 has a different SDK (Software Development Kit) than the NGX which I will need to interface with. Expect it soon.
    Thank you
    I do know that the detective does work, I programmed my T-8 to control the lights....I have not started on the EFIS or the MCPpro...yet.....
    If Steve gets this working, that will be an unbelievable gift...
    Terry
    Great work Steve - as always, looking forward to your 777 update for GoFlight.
    Also have problems getting my GoFlight hardware to work with the new A2A 172.
    Rob
    Hi Rob,
    I had a quick look at the 172 in relation to the MCP PRO and the defaults seemed to work fine. What in particular is the problem?
    Terry, could you share your T8 light programming, I can't seem to get it to work.
    Kevin
    I don't know how to send just the T-8 commands...they are buried in the XML file with tons of other planes. If you use the detective, and click on each light button it will display what the switch does, then all I did was took that data and put it into the switch. But you prob already knew that..
    I don't know if Steve knows how to pull just the switch data out of the file..
    Terry
    I use the keyboard commands from T7 and go thru FSUIPC for the T8.  Till we get the update for the PMDG GFIT.
    Gnacino
