Windows 10 error followed by Program will not start error
After installing the latest version 777 I started P3D and the CDU would not display as it did before with version 747. Shortly after this I recieved a WDF_Violation error with a BSD Restart. Now the Engravity software won't even start. Program closed as soon as you try to start it. Removed and reinstalled, rolled back to version 747 but nothing helps. Will not start and CDU is dead.
I think this may be a problem with the device driver for the CDU. Can you uninstall the Silicon Labs CP210x USB to UART Bridge (it can be found in Windows Control Panel - Device Manager), then click the Scan for hardware changes button to reinstall it.
Check the config of the device driver matches the CDU config (EXEC+S on the CDU).
It may also be work trying a different USB port.
Tried Uninstalling and reinstalling the drive from Device manager no change. EXEC + S does nothing at all. Screen remains blank the entire time. Tried all the different USB ports on the computer with no change. EngravityCDU software will not start at all. Here is the Problem report for the CDU Software
Description
Faulting Application Path: C:\Program Files (x86)\Engravity CDU PMDG Interface\Engravity CDU PMDG Interface P3D.exe
Problem signature
Problem Event Name: CLR20r3
Problem Signature 01: Engravity CDU PMDG Interface P3D
Problem Signature 02: 1.777.0.0
Problem Signature 03: 58b05753
Problem Signature 04: System.Xml
Problem Signature 05: 4.6.1586.0
Problem Signature 06: 575a1409
Problem Signature 07: b7a
Problem Signature 08: 27
Problem Signature 09: N3CTRYE2KN3C34SGL4ZQYRBFTE4M13NB
OS Version: 10.0.14393.2.0.0.256.48
Locale ID: 1033
Additional Information 1: c0f8
Additional Information 2: c0f822e56be60a7fc9a00cf00f41eda2
Additional Information 3: 31f3
Additional Information 4: 31f368b4eca7d6a17f7a2737a5872b24
Extra information about the problem
Bucket ID: d0bae549aa4e4c0c0792d8915085d110 (129379027156)
Is it no longer blue screening? If it is have you got the WDF_Violation error code.
Description
Problem signature
Problem Event Name: APPCRASH
Application Name: Engravity CDU PMDG Interface P3D.exe
Application Version: 1.777.0.0
Application Timestamp: 58b05753
Fault Module Name: KERNELBASE.dll
Fault Module Version: 10.0.14393.479
Fault Module Timestamp: 58256d37
Exception Code: c000041d
Exception Offset: 000da832
Locale ID: 1033
Additional Information 1: c0ec
Additional Information 2: c0ec85655df88f03c1d4bd55e2faae80
Additional Information 3: 258c
Additional Information 4: 258c0bfe053a2f4ecc81de71d0952ea1
Bucket ID: 19ac29536ff3626e287462c5c42f91fc (108771107423)
This is very strange. It seems to be pointing a Simconnect issue with P3D. Try renaming the LM Simconnect DLL in the Engravity CDU PMDG Interface directory.
Please rename the dll back to its original value. Can you try running the software without the CDU connected and P3D running and let me know what happens.
