MCPPro and EFIS not working in Xplane
I have the Interface Tool Running for Xplane. I attached some images that might help.The display is NOT lighting up nor is the EFIS working. I know they both work because they work when I am using PrePar3D
Flightman49
    They need to be configured. Select the device, click the FS Default button and then enable the device.
  • Ok. Works now.........Thank you
  • I think I spoke too soon. The EFIS works fine. The MCPPRO only partially works. The Course, Heading and IAS/Mach work. All other switches and selectors still do not work
    Flightman49
  • Its loads a generic config using standard datarefs and commands. Not all aircraft use or support the standard datarefs and commands, so you either need to load a config from the Downloads section of this website or create a config yourself.
