Interface Tool Version 2.747.0.0
Hello,
I'm having a problem with my MCP Advanced, using Interface Tool Version 2.747.0.0
I've ensured that all options are set to FS Default in GFConfig
I've removed all assignments to all other devices in GFConfig
I've installed the software where my Goflight drivers have been installed.
GoFlight Interface Module.dll is in the dll.xml file.
After starting P3D V3 with any aircraft, I wait for VC cockpit view to load, I then open the Interface tool. It opens ok, three greens, MCP is identified but MCP tab is greyed out. Only Mode Generic Aircraft is shown.
Import Wizzard,Aircraft Power,DIO and Detective are all greyed out.
Below is a copy of the log.
20:33:19 GoFlight Connection Starting.....
20:33:19 SimConnect Connection Starting.....
20:33:20 SimConnect Message Processing Started
20:33:20 GoFlight Connection Started
20:33:20 SimConnect Connection Started
20:33:20 Aircraft Connection Starting.....
20:33:22 FSUIPC: Connected!
20:33:22 Aircraft Connection Started
20:33:22 Simconnect Version: 3.2.0.0
20:33:22 Synchronising Switches & Selectors .....
20:33:22 Synchronising Switches & Selectors: Waiting for SimConnect .....
20:34:25 SimConnect Message Processing Finished
20:34:25 GoFlight Connection Starting.....
20:34:26 SimConnect Connection Starting.....
20:34:26 GoFlight Connection Started
20:34:27 SimConnect Message Processing Started
20:34:27 SimConnect Connection Started
20:34:27 Aircraft Connection Starting.....
20:34:29 FSUIPC: Connected!
20:34:29 Aircraft Connection Started
20:34:29 Simconnect Version: 3.2.0.0
Any help would be appreciated,
Bill
Bill
Hi Bill,
It sounds like the GIT dll is not loading. Try loading P3D and GIT as Administrator. Also check the FAQ entry "FSX/P3D/FSX SE Crashes on start up indicating an error with the Goflight Interface Module".
Also make sure you are using the P3Dv3 version of GIT.
This is a strange issue. Perhaps edit dll.xml and move the GIT module at the beginning or end of the file.
If still no success, tell me all the Goflight gear you have connected including quantities and the date/time of GoFlight Interface Module.dll so I can check things at my end.
Hi Bill,
What version of GIT did you previously use that worked?
Hi Bill,
Can you try renaming My Documents\GoFlight Interface Tool whilst GIT is not running.
I'm away from home till Wednesday. Will get back to you then. Thanks again for all your help.
Bill
I think a clean install would be a good start. Uninstall GIT and make sure the GIT Module entry is deleted from P3D's dll.xml. Delete My Documents\GoFlight Interface Tool.
Install GIT in C:\GIT so that security issues are minimised. Check the dll.xml has the correct entry and location. Copy GFDev.dll from your GoFlight drivers directory into C:\GIT. Run GIT as Administrator and P3D as Administrator. Let me know what happens.
Apologies for the late reply.
I think a remote desktop session would be useful so I can check a few things. When would you be available to do this (in GMT).
