Newbie question - Any Instruction or manual?
Perhaps, it is a newbie question, but could you please tell me how to set up GoFlight module using this interface?
I googled and searched the information how to begin with this, but it seems that I don't have much luck on this.
I have installed and run the interface, and three lights on the interface are green, indicating that everything works well. However, I am having a difficulty to assign PMDG functions to each module. There are so many options and choices, and I don't know which option and function I should choose for a proper work.
I bet there is a comprehensive instruction, or at least example, but I am having a difficulty to find one.
Any advice and suggestion would be greatly appreciated. Thank you for your attention.
Hi Muka,
Yes there are two manuals, one for the Goflight PMDG Interface and one for the GoFlight Interface Tool (assuming you installed this).
The manuals can be accessed from the start button, all programs and then pollypot software. Alternatively you can access them directly within the directory you installed the software (usually "Program Files (x86)\Goflight"
Thank you, Steve.
John
