MESM and NGX interface
I've finally received my warranty replacement MESM and initially it works fine with the 1.1.0 NGX interface. However after a longish flight, 3-4hrs it seems to "go to sleep" so if I want to turn the rotary from "flt" to "cont" during decent I need to restart the interface to get it to wake up! Is there a setting I can adjust to stop it sleeping?? I'm using GF 2.20 but nothing is assigned directly in the GF config.
Paul Gardner
Hi Paul,
It sounds like Windows power management is putting the usb device or hub to sleep. Check your power settings in control panel and in device manager for each of your usb devices.
Hi Paul,
There is no sleep function in the software; it runs continuously. Perhaps the device locked up. I'd try again and double check all your USB devices, hubs and controllers for powering off.
