GIT X-Plane Can not import "Any-Aircraft.xml"
Hello,
I'm new to X-Plane 11 and want to use GIT for the standard C-172. If I set EFIS to Default FS I get the message to import the "Any-Aircraft.xml" with Detective. If I import this XML GIT and Detective freeze and I must quit GIT.
What's wrong with my setup?
Martin
Martin
Hi Martin
I will try replicating the problem later today and come back to you.
another question from a new X-Plane User with GF Modules. Is it normal that in XP the MCP-Pro Altitude digits count up in 10 steps instead of 100 in P3D. If I set 2000 ft and acivate the Autopilot the MCP-Pro shows 2090 ft. Maybe an XP 11 bug.
Also the Starter switch at the SECM only switch the default Cessna one time to start and then goes back to both. How I can set an hold function?
Best wishes,
Martin
Martin
At the moment I've big problems because I switched from P3Dv3 to XP11. Is there a tutorial to make custom settings in XP11 with GIT?
For example I want to turn the starter switch at the default C172 with GIT and the SECM. At the Input event I set Position 1-5 with the sim commands (sim/starters/engage_starter_1). But how I can hold the starter in this position to start the engine? If I turn the knob to start the starter engage for 1 second and goes back to the setting both?
Could somebody makes custom profiles for the default planes in XP11 (if it's final) for the important modules (MCP-Pro, EFIS, SECM, LGTII)?
This would be a big help.
best regards,
Martin
I have no idea how to find and work with the datarefs in X-Plane 11. I'll check your links and try to learn a few things. Unfortunately I have so less time, that I can not fly if I'm searching/learning to program those settings. Therefore I asked in another thread for settings of the SMS Beaver. Maybe you made those settings?
In P3D the most time I worked with FSUIPC to set buttons and axis for Simfunctions for my GF Modules (GF-45, P8, RP-48, T8, SECM and LGT-II). In X-Plane I miss a tool like FSUIPC.
One thing also is interesting. Before I bought GIT for X-Plane I tested the freeware tool "XGoFlight" from X-Plane.org. This tool is from 2013 and there the starter for the XP11 C172 and the Airfoil C172 works without problems (it holds as long as I "press the button", the switch at the SECM). Also if I set the starter in X-Plane on a Saitek button it works. Only with GIT I have this problem. Also the EFIS, which only don't work with standard values in GIT (because this "Aircraft.xml" is needed). And with this old tool from X-Plane.org EFIS also works.
But anyway GIT is the more powerful tool and I don't want to miss it for the big planes like the B777 from FlightFactor.
Hope this helps.
Best wishes,
Martin
I tried it and it works and will hold the key in the start position you just have to send it a 3 to return to the spring loaded position on button or switch release
where I find sim/cockpit2/engine/actuators/? Can't find it at the Input Event list.
Martin
Found it. Had to set "Set +" in Detective, now it works.
Martin
