GF166_DEVICE<n>_ACTIVECONFIG GIT for X-Plane
I am having difficulty configuring
- GF166_DEVICE_ACTIVECONFIG
for my GF166.
For example:
For default COM setup:
BUTTON_LEFT1 and BUTTON_LEFT2 trigger input event GF166_CONTROLS1
BUTTON_RIGHT1 and BUTTON_RIGHT2 trigger input event GF166_CONTROLS2
This is essentially what I want in the button behaviour. Using the LEFT button I want to see my COM1 active/standby and using the RIGHT button I want to see my COM2 active/standby. However, I also would like to see (at a glance) which COM is selected by observing the LEFT/RIGHT Lights. When COM1 data is being displayed I would like to see the LEFT light ON (and RIGHT light OFF) and vice versa.
I experimented with this by setting the following for BUTTON_LEFT1
Light/Disp Data: GF166_DEVICE0_ACTIVECONFIG
Light Action: ON
Light Value 1
This causes the LEFT light to come on when I click BUTTON_LEFT1, but I don't know how to achieve this for the RIGHT side (COM2).
When I configure with the default COM configuration button the GF166_DEVICE_ACTIVECONFIG settings are not automatically set for the lights, so I cannot follow any example.
  • edited April 2017
    Just to add:
    I have read this related topic:
    http://www.pollypotsoftware.org.uk/vanillaforums/discussion/comment/1643/#Comment_1643
    But unfortunately I am still lost:
    Steve's comment was:
    Assuming you have set the second function on the 2nd Active Config for device 0, then set BUTTON_RIGHT2 to use GF166_DEVICE0_ACTIVECONFIG, ON and 2.
    But I don't quite understand this. There was no example to follow with the default COM config so I am still confused. How do I "set the second function on the 2nd Active Config for device 0"?
    and when Steve says:
    "set BUTTON_RIGHT2 to use GF166_DEVICE0_ACTIVECONFIG, ON and 2" does he mean Light Value of 2 for BUTTON_RIGHT2?
  • edited April 2017
    I worked it out.
    Here is the default COM example:
    By default using LEFT Button will set GF166_CONTROLS1 (config 1) so GF166_DEVICE0_ACTIVECONFIG = 1
    for BUTTON_LEFT1
    Light Action: ON
    Light Value 1 <--- The set GF166_DEVICE0_ACTIVECONFIG value when config 1 is active.
    Using RIGHT Button will set GF166_CONTROLS2 (config 2) so GF166_DEVICE0_ACTIVECONFIG = 2
    But in Config 2 it is the value of BUTTON_RIGHT2 that is relevant
    Light Action: ON
    Light Value 2 <--- The set GF166_DEVICE0_ACTIVECONFIG value when config 2 is active.
    This also works for the default NAV config where the LEFT button toggles config 1/2 but the same applies as far as the lights are concerned.
  • Thanks for sharing your findings
  • I am having a VERY hard getting lights to com on to my 166..I appreciate seeing your post and trying duplicate your default com settings to get lights..EXACTLY what do I need to have in my Input boxes?ie..Input Event,Input Action, and Custom Value? also how to move to next setup on each button? Thanks..very confusing to me for some reason...I had them working for a bit, but now unable
