GIT SE problem
After hours of work to update netFX, java, VGA card drivers, GF config and GF interface tool SE, I could not start. I know that it is something about regional settings. When I first bought,GIT first version also did not worked in my computer but later I changed my input and regional settings to English and it worked. But for GIT SE it did not worked also. I am attaching my screen shot, may be it will help you. You will see the strange character I marked. I think only changing that character in your code and recompiling the exe (with unicode, UTF or something like it) will end my trouble.
As an old IT man who swore ten years ago not to deal with computers but only flight simulator
, I will be waiting your action.Now, I will try to return first version of GIT. Hope, it will work after so much changes to get GIT SE worked.
Thanks in advance.
Thanks in advance.
Those odd characters are actually because the code has been obfuscated. The program does support multi-language already.
How far did the program execute? Did you manage to enter the Key? Did you see the PMDG SDK notice? Are there files in My Documents\GoFlight Interface Tool and if so, please delete them all and try again.
The latest release uses the very latest .NET Framework and some people have had issues because its out of date on their systems.
It may be worth renaming My Documents\GoFlight Interface Tool so GIT does not use any old setting files (not the Program Files (x86)\GoFlight directory)
According to : https://msdn.microsoft.com/tr-tr/library/hh925568(v=vs.110).aspx I checked NET frameworks.
And then checked Windows update:
And then I uninstalled Go Flight drivers and GIT (first version ) , I deleted all the related files:
With ccleaner I cleaned up the registry. Most of these steps and later steps, I restarted the pc.
I made a clean install of Goflight drivers, restart and GIT SE. I enter my password (between errors)
Nothing changed:
Thanks for your help and regards.
