XP11 MCPro B 737
Hello. I'm right with the nerves. So, have X plane 11. I bought GoFlightinterfacetool for xplanet. First it worked. I start the sim and goflightinterfacetool. Configuration of B 737 has been uploaded, and it has worked. Then I tried to adjust the buttons. Suddenly there is no more. All three are green. But quite right where Aircraft stands there are all crosses red. I can not click on mcpro klickne or Import Wizard, the Detective. All other airplanes just do not go B737 (although it still worked at the beginning)
  • Clear the config by renaming My Documents\GoFlight Interface Tool.
  • Already tried, remains the same. Have then deleted GoFlightinterfacetool (also documents) and reinstalled. But did not help. Somewhere my settings are stored, someone an idea where?
  • It looks like your b738 aircraft directory may be corrupt or parts of it moved somewhere.
  • This is original aircraft :-( has not changed anything. It worked first. Then I set the settings suddenly crashed. And since then it has stopped working. The only thing I've changed is that you can walk through the plane walls so I can see windows.
  • All those red X's mean the aircraft files are missing.
  • Thanks Steve. :) One problem less. You said that there is something missing. So I deleted the B 737.
    Cd 1 inserted. And X plane 11 repaired. So B 737 re-installed. Now the problem is lifted.
    What is still disturbing me now is the settings of goflight mcpro. The buttons do not match B 737. Some work properly, and some do not. I have downloaded from the goflight page configuration file for B 737 but it does not kommplet. Since the manual setting is very complicated, I wonder if it is somewhere the right attitude can download.
  • What file did you download? Do you have a link?
  • https://www.pollypotsoftware.org.uk/downloads.html.
    There files for B 737 and 737 v5 downloaded. Then I start x plane 11 then interfacetool. I click on ImportWizzard- wait until imput is finished. Then the goflight mcpro shows on screen 000000. It is not working yet. I click on interfacetool mcpro there on device0 enable and on FS default. Then the device works but not quite right
  • None of those are for the default 737, they are for add-on aircraft so they won't work properly if at all. You will get some functionality by simply clicking the Default FS button on the MCP PRO tab.
  • Makes sense. And an idea where I get configuration file for default B737? In the Internet I have not found anything :-( Why do you find on the INternet page the file for Addons but not for default aircraft? :-( :'(
  • Does not anyone know?
  • edited June 2017
    Why don't you download the EADT 737 from here http://www.eadt.eu/index.php?new-x737-version-5 and then use the EADT 737 profile for GIT.
  • Thank you for your comment
    Have it downloaded. The model looks very bad in cockpit but is not so important at first. Mcpro does not go here either. Many times I do what interfacetool wrong. I start xplane11, select the plane and start. Start the Interfacetool program. Click Import Wizzart. Select the file 737v5 which I have downloaded (configuration file). Wait until imput complet. and that was it. But mcpro shows only 000000. Sadly, it's not possible
  • What was the state of the MCP in the Virtual Cockpit? If it was not powered up it will show zeroes.
  • it's clear. In game, everything goes right. And when I click on default fs settings, this works. It then shows the numbers as in cockpit. If I but the configuration file load shows it only 000. Restarts tried. Updated. What can I update? Which programe are needed?
  • Perhaps it no longer works with the latest version, I will have to check and come back to you.
  • Actually I have just remembered putting a new EADT file in the download section created by Manikandan Venkataramanan. Try that.
  • Okey thanks. Have it downloaded. But can not just try it out. As soon as I have time, I say whether it has worked or not.
  • Wow. Good and bad news. Good news that it now Almost worked. Thank you very much. But there is still a little problem: the buttons do not light green when you click on the Button. Would be nice if that would still work. And the Curse can not turn. But otherwise everything goes.
  • Contact the author in this forum and check if he set the things up that you need.
