XP11 MCPro B 737
Hello. I'm right with the nerves. So, have X plane 11. I bought GoFlightinterfacetool for xplanet. First it worked. I start the sim and goflightinterfacetool. Configuration of B 737 has been uploaded, and it has worked. Then I tried to adjust the buttons. Suddenly there is no more. All three are green. But quite right where Aircraft stands there are all crosses red. I can not click on mcpro klickne or Import Wizard, the Detective. All other airplanes just do not go B737 (although it still worked at the beginning)
This is original aircraft :-( has not changed anything. It worked first. Then I set the settings suddenly crashed. And since then it has stopped working. The only thing I've changed is that you can walk through the plane walls so I can see windows.
Cd 1 inserted. And X plane 11 repaired. So B 737 re-installed. Now the problem is lifted.
What is still disturbing me now is the settings of goflight mcpro. The buttons do not match B 737. Some work properly, and some do not. I have downloaded from the goflight page configuration file for B 737 but it does not kommplet. Since the manual setting is very complicated, I wonder if it is somewhere the right attitude can download.
There files for B 737 and 737 v5 downloaded. Then I start x plane 11 then interfacetool. I click on ImportWizzard- wait until imput is finished. Then the goflight mcpro shows on screen 000000. It is not working yet. I click on interfacetool mcpro there on device0 enable and on FS default. Then the device works but not quite right
Makes sense. And an idea where I get configuration file for default B737? In the Internet I have not found anything :-( Why do you find on the INternet page the file for Addons but not for default aircraft? :-( :'(
Have it downloaded. The model looks very bad in cockpit but is not so important at first. Mcpro does not go here either. Many times I do what interfacetool wrong. I start xplane11, select the plane and start. Start the Interfacetool program. Click Import Wizzart. Select the file 737v5 which I have downloaded (configuration file). Wait until imput complet. and that was it. But mcpro shows only 000000. Sadly, it's not possible
Okey thanks. Have it downloaded. But can not just try it out. As soon as I have time, I say whether it has worked or not.
