GIT v 2.747.2 Crashes with P3D V4
Hi i am using go flight version 2.28 with GIT v2.747.2 and i keep getting a crash when trying to start GIT.
I get application halted ... and a message the invocation of the constructor on type 'A.WI' that matches the specified binding constraints threw an exception this is also kicking up an error from .NET Framework can you help?
File attached with the errors
On a related note, it appears PMDG needs LM to release a patch before they can release the -300 expansion of the T7. So perhaps this will help expedite the hotfix to get GIT working.
