GIT for P3D V4 v2.747.3.3 intermittent with PMDG 747, but works with PMDG 777
I had good success with v2.747.3.3 and PMDG 777, but was getting intermittent functionality with the PMDG 747.
I've checked the 747QOTSII_Options.ini and there is the correct broadcast entry:
[SDK]
EnableDataBroadcast=1
Checking the GIT log and I was getting long list of
"Send Control Data: Too Many Retries"
I exited P3D V4 (21686) and restarted both V4 and GIT. This time GIT worked with the 747.
Once working, it seems fine, no issues.
Cheers, Rob.
[SDK]
Cheers, Rob.
Need to monitor.
Robert
P.S. There are no other addons running and the SDK broadcast option=1
I suspect there are still issues with P3D and the PMDG port to 64bit. GIT itself is 99.999% the same code; the only changes being some routines to recognise the registry and directories of v4. The big change was the GIT plugin which had to be converted to 64bit, but all PMDG aircraft do not use this. Hence why I think these issues are nothing to do with GIT.
Please make notes of issues and how to reproduce them and we can forward them on to P3D and PMDG.
It's very important that you let me know how to replicate this issue. What steps do you take from start to finish.
Robert
