goflight mcp pro
I am running xplane 11 and installed goflight and pollypot software.When i start goflight tool all three green lights are on and mcp panel shows all 0's,Buttons and switches have no effect.What am i not doing right?
I know when I was testing, some functionality of the 738 MCP could not be mapped.
Detective will show Dataref changes only.
You will need to read up on the concepts (https://www.pollypotsoftware.org.uk/support/user-guide/goflight-interface-tool-x-plane/34-concepts.html) and process (https://www.pollypotsoftware.org.uk/support/user-guide/goflight-interface-tool-x-plane/36-detective.html).
You could of course try searching for lnav in commands or datarefs and then try them on the MCP PRO.
Are you flying Zibo's Boeing B738-800 modified version ? (http://forums.x-plane.org/index.php?/forums/topic/111305-boeing-b738-800-modified/). I've mapped the GF-MCP Pro, GF-EFIS, 2x GF-166 (Com and Nav) and the GF-LGT II.
The only problem I have is the map mode position switch. The mode changes in the MFD but the position switch doesn't animate in the sim. I'm still working on that one. There's also some mucking around in the aircrafts folder but I'll provide a readme file to spell out what needs to be done after you install the aircraft.
Steve,
What specific files need to be included in the zip file?
Thanks.
