I downloaded the latest and installed and then applied the patch to V4 - Not wokring
I firnst installed the recent donwload (yesterday) and then I applied the v4 client patch from LM and rebooted but simconnect is yellow.
Log
12:37:49 GoFlight Connection Starting.....
12:37:49 SimConnect Connection Starting.....
12:37:50 GoFlight Connection Started
12:39:00 SimConnect Message Processing Started
12:39:01 SimConnect Connection Started
12:39:01 Aircraft Connection Starting.....
12:39:04 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
12:39:04 Aircraft Connection Started
12:39:04 Simconnect Version: 3.2.0.0
12:39:04 Synchronising Switches & Selectors .....
12:39:04 Synchronising Switches & Selectors: Waiting for SimConnect .....
12:39:12 SimConnect: Event Received: Start
12:39:12 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
12:39:12 SimConnect: Event Received: SIM, 0
12:39:12 SimConnect: Event Received: PAUSE, 0
12:40:09 PMDG SDK option is OK in Prepar3D
12:40:09 SimConnect: Event Received: Aircraft Type Changed
12:40:09 GoFlight Connection Starting.....
12:40:09 SimConnect Message Processing Finished
12:40:10 SimConnect Connection Starting.....
12:40:11 GoFlight Connection Started
12:40:11 SimConnect Message Processing Started
12:40:11 SimConnect Connection Started
12:40:11 Aircraft Connection Starting.....
12:40:12 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
12:40:12 SimConnect: Event Received: SIM, 0
12:40:12 SimConnect: Event Received: PAUSE, 1
12:40:12 Aircraft Connection Started
12:40:12 Simconnect Version: 3.2.0.0
12:40:13 SimConnect: Exception Received: EVENT_ID_DUPLICATE
12:40:13 SimConnect: Exception Received: ERROR
  • Yellow LED does not necessarily indicate a problem and is quite normal. What exactly is not working?
  • Mea Culpa.. It is working fine.. Sorry about that.. please feel free to delete this thread.
