GF45 and PMDG interface 1.2.1.0
Using PMDG interface 1.1.0 I have 3 x GF45's set to LDG ALT. FLT ALT and AUTO BRAKE. All works perfect.
I updated to 1.2.1, copied over my user files and I no longer have the GF45 assignments. I can manually assign LDG ALT but not the other two.
I revert back to 1.1.0 and all is well again?
Paul Gardner
Hi Paul,
There is a bug in GIT and the Interface for the GF45's. Goflight has sent me one to test with, so a fix will appear soon.
Great. Thanks for the update.
Also when we update the GIT can you please confirm which user files we should copy over. Is it just the "user.cfg"?
Paul
Hi Paul,
This is now fixed.
user.config contains so little information now, its probably not worth the hassle.
Copy user.config over to the latest version which is 1.2.2. Transfer of your settings will occur to readable xml files in My Documents\Goflight PMDG Interface.
After that you can pretty much ignore user.config for future versions.
Hi David,
Just tried your config and it works fine. Try it again and let me know.
